ASCE 7-10 Wind Speeds Missing From Tables
As we all probably know by now, ASCE 7-10 includes basic wind speed maps for each risk category. So for a particular site, you would have one basic wind speed for a risk category IV structure, and a different (lower) basic wind speed for a risk category I structure. The basic wind speeds range from 100 mph (for the west coast and risk category I) to 200 mph (for the southern tip of Florida and risk category III or IV). Here's the problem: The range of basic wind speeds in the tables in Chapters 27 through 30 starts at 110 mph and goes up to 200 mph. If I choose to use an analysis procedure that relies on one of these tables, what should I do if my basic wind speed is 100 or 105 mph? This would be the case for most risk category I structures in the US.
Thanks in advance.
Thanks in advance.
RE: ASCE 7-10 Wind Speeds Missing From Tables
As an alternative, you can be conservative and use the minimum table value of 110 mph. It will be slightly higher than you need.
Personally, I never liked those tables in ASCE 7-05. Too many exceptions and adjustments. I haven't had a chance to use the ones in ASCE 7-10 yet.
Check http://www.asce.org/
As a side note, I would calculate wind loads manually at least once before I used the tables. I hate to depend too much on the work of others until I can reproduce it. But that's just me.
