Delete pattern and add new title block
we want to swith from pattern to the new title block.
Open a drawing, how can I delete pattern ?
If I edit the sheet and change from one format to other, the new title block is not shown.
How can I switch ?
How can I switch ?
Thank you...
Using NX 8 and TC9.1
RE: Delete pattern and add new title block
use filters an select all
changing sheetsize doesn't respect the new titleblock position - not show - a layer issue?
this is our situation.
We want to switch from old pattern title block Format->Pattern, etc.. to the new title block born with NX8.
So I open an old drawing, save as and make a new revision.
Now I want to use the new NX8 title block.
I tried to use the filter pattern an select all, but doesn't select nothing.
Again, if a make a new file, the new title block is present, but I'm not able to show if I want to change the sheet dimension from one dimension to other or if I want to change the pattern to the new title block.
PAX file for the new title block like drawing and sheet are present and setted correctly because for new file all work great.
Thank you...
www.nxjournaling.com
Thank you...
