Annoying dimensioning behavior in draft
There's this thing in SE (draft mode, ST4) where it'll automatically select the line you're hovering over with your mouse when dimensioning. I like keyboard shortcuts/spacemouse buttons so I'm often hovering over a line when activating a dimensioning command. As a consequence when I want to dimension something it will have already selected the line I've been hovering over and I always need to cancel and reenter the command in order to get to what I want to dimension. Is there any way to turn this off? It's sooo %$# annoying...
RE: Annoying dimensioning behavior in draft
It is only selected if you click or use the keyboard shorcut command.
Cancel a selection/command with ESC.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
