Pattern not loaded
Pattern not loaded
we work under Teamcenter.
We have exported a project locally to send to our supplier to complete the project.
We have exported also the pattern locally in the same folder where project files reside, but when we open a drawing with the master model approach, the title block (pattern) is not visible, sure not loaded.
Exist a procedure to reload the pattern automatically, manually o via macro ?
Thank you...
Using NX 8 and TC9.1
RE: Pattern not loaded
Ben Loosli
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I tried to follow your suggestion, but we work under TC and when we export the project, the drawing look for a pattern called like %PAT VYPtKe2nHhbWqD.
Thank you...
We were told to load the formats (patterns) outside of the PDM and reference them from the external location. We also have to have a copy of the format in the PDM for when a file is retrieved after initially being created with the external format. TC may work differently, but our files are looking for the actual name of the format, not the PDM encrypted filename that your exported files seem to be looking for.
If you tried the pat_dir folder with your pattern, retry it with a renamed pattern file matching the TC internal filename.
Ben Loosli
you have wrote :retry it with a renamed pattern file matching the TC internal filename.
Yes, after your primary suggestion, I tried this.
The problem is that NX store in the file each pattern you have used.
For example, I start to create a A4 format drawing, but after some saves and modification I need to switch to A3 because I've added some more views.
So NX save in this file like some type of info 'pattern A4' and 'pattern A3'.
When I export this file outside TC, in native, using Format->Pattern->List pattern errors, NX lists %PAT VYPtKe2nHhbWqD and %PAT VYtKKf45HhfIhF.
So, if I rename pattern A3 and pattern A4 whit this name, NX drawing show each pattern.
For this we have decided to change from old format (pattern) to the new title block.
The new title block are ready, but as other thread, I'm not able to delete old pattern and load the new title block.
GTAC doesn't have experience on this new title block, so I need to ask here and try myself.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
now it's more clear.
So if I want to dismiss 'Patterns', for new files, I use the new templates that contain the new title block. Right ?
If the drawing exist with the old 'Patterns', for example I make a new revision, how can use the new title block ? Only via some type of automation ?
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
always more clear.
So, if I want that this procedure must be transparent to the users, I will need some type of macro.
The last question, in this topic http://www.eng-tips.com/viewthread.cfm?qid=221010, you talk about yours title block used for demos.
Yours title blocks are symbols.
Can I import my 'pattern' in a drawing, convert to lines and texts and create a symbol title block for each format, inside each template ?
Which are the benefit to use NX8 Drawing Border/ general table converted in Title Block, respect to lines and texts converted in symbols under 256 layer ?
I thought symbol, because can be related to the master symbol, so if I change the master symbol, all old drawings will have the new modified title block without extra works to the NX users when drawings are open.
Thank you...
As for the automation, I'll have to leave that to someone else.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
