tool list in nc program
hi,how add to my nc program a tool list(the description,mom_tool_description) at the begin of program?
i see this comand but don´t works with mom_tool_description.
Need reprocess it?
Thnaks
CODE -->
global ptp_file_name mom_definition_file_name mom_output_file_full_name
global mom_output_file_directory mom_output_file_basename mom_output_file_suffix
global mom_warning_info
global mom_machine_time mom_group_name mom_operation_name mom_part_name
global mom_tool_count mom_tool_use
global mom_logname mom_ug_version mom_date mom_machine_name
set tm1 [clock seconds]
set tm2 [clock format $tm1 -format "%M:%S"]
MOM_log_message "MOM Start = $tm2 "
set tmp_file_name "${ptp_file_name}_"
if {[file exists $tmp_file_name]} {
  MOM_remove_file $tmp_file_name
MOM_close_output_file $ptp_file_name
file rename $ptp_file_name $tmp_file_name
set ifile [open $tmp_file_name r]
set ofile [open $ptp_file_name w]
set temp ";%_N_"
set temp1 $mom_output_file_basename
set temp2 _MPF
set stroka [concat $temp$temp1$temp2]
puts $ofile "$stroka"
set temp ";$"
set temp1 "PATH=/_N_WKS_DIR/_N_WORK_PROGRAMS\_WPD"
set stroka [concat $temp$temp1]
puts $ofile " "
set path $mom_part_name
puts $ofile ";(PART: $path)"
if {[info exists mom_operation_name] == 0} { set mom_operation_name "" }
if {[info exists mom_group_name] == 0} { set mom_group_name $mom_operation_name }
puts $ofile ";(Program: $mom_group_name)"
puts $ofile ";(Date:$mom_date User:$mom_logname)"
puts $ofile ";(MACHINE: $mom_machine_name, Siemens CNC)"
puts $ofile ";(MACHINE TIME: [format "%.2f" $mom_machine_time] MIN)"
puts $ofile " "
puts $ofile ";(----------- TOOL LIST -----------)"
for { set nn 0 } { $nn < 99 } {incr nn} {
  if {[hiset mom_tool_use($nn,0)] && [hiset mom_tool_use($nn,1)]} {
    set a [scan $mom_tool_use($nn,0) %d tn]
    set str [format "%s %.2f" $tn $mom_tool_use($nn,1)]
    puts $ofile ";(TOOL NUMBER $str MIN)"
puts $ofile ";(--------- END TOOL LIST ---------)"
while { [gets $ifile buf] > 0 } {
   puts $ofile $buf
close $ifile
close $ofile
MOM_log_message "MOM End = $tm2 "
MOM_open_output_file $ptp_file_name
