DXF AUTO EXPORT VB PROGRAM 32 BIT VS 64 BIT
We have modified program I got off this site from Cowski that exports out a DXF using the CGM import/Export. It used to work well in the XP 32 bit system. Since we have moved to the windows7 64 bit the program does not work now. What could be hanging this program up from working on one system and not the other?
I have attached VB file
The error I get is invalid DXF message at the end of the program
RE: DXF AUTO EXPORT VB PROGRAM 32 BIT VS 64 BIT
Below is my latest code from the ExportDXF subroutine; I've highlighted a few differences I noticed.
  • I probably should, but my current code does not, call the validate method as your code does. When validate returns a False value, your code aborts the export operation. I put in a call to the validate method as a test and it did return a True value. The Validate method returns false if there is insufficient input to call the Commit method.
  • My code sets the Annotations and Structures properties of the dxfCreator, perhaps these are the "missing" inputs that the creator needs.
  • I've commented out the call to the SetUserCredential method. I've had users on TC test this and since we were only passing in empty strings it didn't seem to be required.
CODE
Sub ExportDXF(ByVal inputFile As String, ByVal outputFile As String)
    Dim dxfdwgCreator1 As DxfdwgCreator
    dxfdwgCreator1 = theSession.DexManager.CreateDxfdwgCreator()
    dxfdwgCreator1.SettingsFile = dxfSettingsFile
    dxfdwgCreator1.InputFile = inputFile
    dxfdwgCreator1.OutputFile = outputFile
    dxfdwgCreator1.FileSaveFlag = False
    dxfdwgCreator1.ObjectTypes.Curves = True
    dxfdwgCreator1.ObjectTypes.Annotations = True
    dxfdwgCreator1.ObjectTypes.Structures = True
 'next line controls dxf file version
    dxfdwgCreator1.AutoCADRevision = DxfdwgCreator.AutoCADRevisionOptions.R2004
    dxfdwgCreator1.FlattenAssembly = False
    dxfdwgCreator1.ViewEditMode = True
    dxfdwgCreator1.LayerMask = "1-256"
    dxfdwgCreator1.DrawingList = ""
    dxfdwgCreator1.ViewList = "TOP,FRONT,RIGHT,BACK,BOTTOM,LEFT,TFR-ISO,TFR-TRI"
 'dxfdwgCreator1.SetUserCredential("", "", "")
    Try
        Dim nXObject1 As NXObject
        nXObject1 = dxfdwgCreator1.Commit()
    Catch ex As Exception
        MsgBox("Error in DXF export subroutine" & vbCrLf & ex.GetType.ToString & " : " & ex.Message, MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, "DXF export error")
        lg.WriteLine("Error in ExportDXF subroutine: " & ex.GetType.ToString & " : " & ex.Message)
    Finally
        dxfdwgCreator1.Destroy()
    End Try
End Sub
First, I'd try adding the Annotations and Structures lines; if it still doesn't work, try commenting out the SetUserCredentials line. If it still doesn't work after that I'd check the log file after running the journal to see if there are any hints in there as to why it isn't completing. Also, I'd check to make sure the latest .NET framework and patches are installed.
As a last resort, I'd try commenting out the call to the Validate method just to see what happens.
www.nxjournaling.com
I have tried your suggestions. But they did not work. I get a message box please see attached. Something about an embedded object cannot be deleted in isolation. Thanks for the feedback. I was thinking of permissions on our machines. We have limited write access to certain areas of our c: drives. I have checked with IT and we have write access to the path shown on the error messages. What locations on our hard drives do I need full control access to on our c:drives?
Cool once again thanks. We will look into these issues. Sounds like it is a windows 7 issue. We will try this and will post back the results
Found out what the issue was through GTAC. It had to do with "validate" I commented out 'dxfdwgValid = dxfdwgCreator1.Validate()
and added dxfdwgValid = true
The GTAC guy did not understand why the Validate kept sending back a False Flag. So this now works. Once again thanks for the Help cowski.
