using a journal to call a grip program
Hi Everyone
wondering if anyone can help me out. i am in need to call a grip program from a journal, and when it finishes have it pass control back to the journal. Is this possible ? If so does anyone have an example I could possibly use to get started. Appreciate anything you can tell me.
windows 7 and nx 8.0
Smitty
www.changes-consulting.com
RE: using a journal to call a grip program
This is possible, you will need to use the ExecuteGrip method. Below is a code sample from Siemen's GTAC solution center
CODE --> GTAC(vb)
'Date:  09/19/2007
'Subject:  Sample NX Open .NET Visual Basic program : call grip from vb and print args
'Note:  GTAC provides programming examples for illustration only, and
'assumes that you are familiar with the programming language being
'demonstrated and the tools used to create and debug procedures.  GTAC
'support professionals can help explain the functionality of a particular
'procedure, but we will not modify these examples to provide added
'functionality or construct procedures to meet your specific needs.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.UI
Imports NXOpen.Utilities
Module call_grip_from_vb_and_print_args
  Dim s As Session = Session.GetSession()
  Dim ui As UI = GetUI()
Sub Main()
Try
    Dim num1 As Double = 2.0
    Dim num2 As Double = 55.2
    Dim text1 As String = "Otto"
    Dim text2 As String = "Karl"
    Dim inputArgs(3) As Object
    Dim gripObj() As Object
    inputArgs(0) = num1
    inputArgs(1) = num2
    inputArgs(2) = text1
    inputArgs(3) = text2
    ui.LockAccess()
    Dim grip_executable As String = "c:\print_api_args.grx"
    gripObj = s.ExecuteGrip(grip_executable, inputArgs)
    ui.UnlockAccess()
Catch ex As Exception
    s.ListingWindow.Open()
    s.ListingWindow.WriteLine("Error: ")
    s.ListingWindow.WriteLine(ex.GetBaseException.ToString())
End Try
End Sub
  Public Function GetUnloadOption(ByVal dummy As String) As Integer
      Return Session.LibraryUnloadOption.Immediately
  End Function
End Module
'$$ GRIP Source called by VB.NET
'$$ Please remove the first character
'$$ in each line to compile!
'$$ Declarations.
'    number / zahl1, zahl2
'    entity / object
'    string / text1(132), text2(132)
'$$ Register and initialize the argument list
'    ufargs / zahl1, zahl2, text1, text2
'$$ Print the arguments
'    PRINT/ 'Argument1 = ' + FSTR(zahl1)
'    PRINT/ 'Argument2 = ' + FSTR(zahl2)
'    PRINT/ 'Argument3 = ' + text1
'    PRINT/ 'Argument4 = ' + text2
'$$ Return control to the VB program.
'    halt: halt
www.nxjournaling.com
