Relief Valve threaded to seal sytem
Hi People , Is It normal to use relief valve threaded instead of flanged to use on barrier fluid . The pump will work with C5+ (about 1.2 % of benzene ).
I haven´t see anywhere threaded , the aplications I know is only flanged connection .
thanks
thanks
RE: Relief Valve threaded to seal sytem
I'm not sure where the cut off is with valve size. You should be able to distinquish this easily in a Parker-Hannifin catalog or equivalent manufacturer.
Cockroach
The flush plan that I´ll use is the Plan 53C (pressurized ) . The pressure is about 18 kgf/cm2.
Anybody knows if is there any API advise about flanged ot threded to seal sytem . I have looking for , but I didn´t see anything about.
I walk on refinery and I only see flanged .
