2013 Install Issue
2013 Install Issue
I'm having an issue with my HUL install of 2013. The install seemed to go fine just like I've done 100 times before. However, when trying to run SW after about 10 seconds if freezes and forces me to do a hard restart on my computer. I can't even get control of my task manager. 2012 worked just fine. I've done a repair install, and that didn't help. Any suggestions?
Win 7 64-bit, 6Gigs of RAM
RE: 2013 Install Issue
I'm guessing you did a clean install?
Jeff Mirisola
My Blog
Have you considered a complete, clean uninstall & reinstall of SW?
I've never used the HUL setup (single, standalone user for work & home)
Dan
www.eltronresearch.com
Dan's Blog
Contact your VAR. My VAR sent me a new HUL for our 2013 installation, although your issues sounds like more of one of stability. If it were completely a problem with the S/N I would expect you'd get a message stating such.
- - -Updraft
Dan
Dan's Blog
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Jeff Mirisola
My Blog
Dan
Dan's Blog
Dan
Dan's Blog
Jeff Mirisola
My Blog
Dan
Dan's Blog
CODE
For the record, what GC are you using?
Dan
Dan's Blog
