Low temperature pipe support packer material
Peers,
I'm looking for some advice for non-metallic pipe support packer material which can withstand low temperature. Piping is low temp CS A333Gr6 and will see temp as low as -60C during blowdown. There are some structural contact point which requires to be isolated from low temp pipe. Preferably looking for a non-metallic packer / pad. Any help would be appreciated.
RE: Low temperature pipe support packer material
You can find the supports you are looking for in:
Link
