OLTC - On Load Tap Changer
Dear all,
I would like to seek opinion how you guys review the submission approval for transformer accessories transformer - OLTC.
As far as I know, substation here, they prefered MR Germany - OLTC.
RE: OLTC - On Load Tap Changer
-Rated voltage, rated current and rated step voltage match with the maximum values of transformer during in service or testing at factory
- Guaranteed number of operations before overhaul
- Type test report in line with relevant IEC
- Minimum protection provided - bursting plate, surge relay, out of step relay
I would like to seek clarification on regards your suggested few points;
i) Guaranteed number of operations before overhaul, overhaul means maintenance as I suppose ?
ii) Bursting plate,surge relay, out of step relay, what is that ? kind new terms for me.
ScottyUK,
Your utilities prefer Reinhausen yeah.
Diverter switches is referring the tap-changer switcher right ?
You should look at the maintainability of the design: top-mounted tapchangers are common but you will need to provide a lifting frame or gantry to remove it for maintenance. A high voltage OLTC is a substantial size but is also a fairly delicate piece of precision engineering - removing it and replacing it in the tank is not a trivial task.
Make sure that you determine whether the OLTC manufacturer, or perhaps the transformer OEM, have suitably trained and experienced personnel available in your location. You might consider integrating a long-term service agreement with the manufacturer as part of the bidding process.
Number of operations meant arcing contact life after which contacts to be changed.Bursting plate=pressure relief device fitted to arcing chamber, surge relay= relay mounted between the diverter chamber and its oil conservator to detect excess surges from faulty diverter switch.
You mention lifting frame / gantry, do you mean provide on the transformer or OLTC itself ?
Well, honestly, I havent see any high voltage power transformers myself.
Do you agree what prc stated in his reply on "Once upon a time almost all leading transformer manufacturers were making OLTC.Then the mergers started due to economies of scale.In 1960's and 70's UK had atleast 4-5 well known tap changer makers, but today none.(Scotty can correct me)Today there are two popular designs available around the world -MR and ABB,both reputed and reliable.There are many smaller manufacturers in China &India with limited markets." ?
prc,
Minimum protection means the OLTC design specifications suppose to have these kind protection for itself.
prc knows the transformer industry rather well.
Reinhausen and ABB are both well-respected manufacturers and are often specified by name in client specifications. The old British manufacturers like Ferranti, English Electric / AEI / GEC, Fullers, Hawker-Siddeley and ATL are all gone. I think Brush are still in the business or were until recently: I have an idea that Brush merged with the old ATL company and Hawker-Siddeley under FKI's ownership but I might be wrong about that.
Appreciate for your sharing input.
prc,
I'm wating for prc reply on regard minimum protection. Does it give minimum protection for power transformer or for OLTC itself ?
OLTC will have its own surge relay and pressure relief device. Transformer will have a separate pressure relief device. So the protection will be two separate and independent entities.
In the operating manual for the Reinhausen Vacutap VR OLTC, the instructions have a warning at the beginning of the manual that states "Connect the protective relay in such a way to ensure that the transformer is immediately disconnected when the protective relay is tripped." The standard RS 2001 surge relay includes just a single tripping contact, with multi contact versions available upon request. The relay resets once the flow stops, so either a seal-in relay or an alarm contact is needed to identify which phase trips.
