Variable Fillets
Variable Fillets
Does any one if you can use a variable radius to not just change the fillet radius along the edge but to make the radius themselves non constant.
I mean have the distance the fillet extends be longer on one surface than the other?
RE: Variable Fillets
Dan
www.eltronresearch.com
Dan's Blog
It is going to be extremely difficult to make this fillet by a sweep. I'd be pulling my hair out.
You can add a chamfer with different length legs, then you can add fillets to the chamfer?
Frank
Dan
Dan's Blog
