Links to Excel
Links to Excel
Links to Excel
Is it possible to link data from cells in Excell to data fields in Microstation?
RE: Links to Excel
Yes it is. Depending on your version of MicroStation you can copy and paste a spreadsheet with links. Look on the Bently website, I found information there that will help you get-r-done.
RE: Links to Excel
I am familiar with pasting a complete spreadsheet into Microstation by using the Axiom application. But after doing that or before, I would like to link a specific cell (A24 for example) to print the text in that cell on the drawing in a specific location.
RE: Links to Excel
Seeker2 - Did you get it figured out? Looking in V8i help really quickly I found this: "Using OLE Container"
Take a look at "Using OLE Container" it walks you through the process.
RE: Links to Excel
I have Version 7, I guess this will only work with Version 8, it that correct.
RE: Links to Excel
No, I have seen excel links before Bentley took over MicroStation. You just need to search the web. A quick google search resulted in this:
http://communities.bentley.com/communities/other_c...
Good luck and have fun with it.
RE: Links to Excel
Thanks for your help.
