New to Abaqus - What is the different between scripting (.py) and input files (.inp)
I am new to Abaqus but have experince in Ansys. I would like to use MATLAB to generate some sort of input (.py or .inp) for Abaqus to run. I plan to use MATLAB to change parameters and optimize based on results. What I am getting lost in is I keep seeing stuff about "scripting" which references .py files and python coding and seems to have a different syntax when compared to .inp which seems like basic input files. What is what? Also is there a good reference/glossary of all the .inp commands and their syntax? Is there a good getting started guide? Every tutorial I find is either about the GUI or is three steps ahead of where I currently am.
Thanks in advance.
Thanks in advance.
RE: New to Abaqus - What is the different between scripting (.py) and input files (.inp)
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
What is a .inp vs a .py?
This is all pretty basic and explained in the manual. Input file keywords (not commands) can be found in the keyword manual.
I am sure I will be back with questions, but off to a better start now.
