NX6: isoparametric curve through point ?
is it possible to extract isoparametric curve passing through a point in NX6?
RE: NX6: isoparametric curve through point ?
That specific functionality was implemented in NX 8.0 when we enhanced the Isoparametric Curve function to allow the selection of a specific point on a face, along with several other enhancements, including making Isoparametric Curves a fully functional feature associated with face being selected.
About the best that you can do today (with NX 7.5 or older versions of NX) is to first determine the U/V location of the point of interest on a Face and then manually enter those values into the current Isoparametric Curve creation function.
Now you could write a simple program which would allow the selection of a point on a face, extract the U/V parameters of this point and then create an Isoparametric Curve on that same face using these derived U/V values.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John,
Could you point me in the direction, where I'd start with creating such program or at least the name of the API.
Oleg
I know that it can be done using GRIP, so I would expect that it wouldn't be a problem using NX Open (AKA User Function). Now as to whether it could be done using a Journal, I'm not so sure as there is no actual interactive function which will return the U/V parameters of a face based on selecting an existing Point object.
BTW, can you execute GRIP programs?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Toost is correct. I hadn't used this function for awhile and had lost track of exactly how it worked. I guess it's true what they say, When you get older your memory is the second thing that goes... winky smile
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am a little forgetful about NX6 but i guess if you have a shape studio license then SECTION ANALYSIS too can be used for creating isoparam passing through a point.
Best Regards
Kapil Sharma
Toost, your solution works. Thank you.
John, yes grip works. I'll start digging help on it, as I run into problems requiring automation. Thank you.
