Calculate NPSHa for VS4 pumps
Hi All
Does NPSHa for VS4 pumps calculate as usual as OH2 pumps?
RE: Calculate NPSHa for VS4 pumps
http://www.eng-tips.com/viewthread.cfm?qid=314350
NPSHA = (absolute press above the liquid - vapour Press.)X 10 / S.G + liquid level above the impeller inlet.
If you plan to use a VS4 where NPSH is the limiting factor (in an application other than an open sump or a tank) then you might have the wrong pump type.
