coil cord, aircraft control wheel
Looking for a company that makes/sells coil cords that will meet the flammibility requirements of 14 CFR 23.1359 or 25.1359.  These cables used on older aircraft control wheels typically for autopilot disconnect, mic, etc.
RE: coil cord, aircraft control wheel
Did you ever find something???... I need it to... If so, please leave a reply please....thanks
yes, I found a product at W.L.Gore & Associates Inc. (www.gore.com) called RCF 5318 which at least has a UL rating.  I suggest contacting Gore directly.
thanks...i will check it out...
