peak flow calc in mobile home park
For a mobile home park using 8000gpd or 5.5gpm I used a peak flow factor of 30 (small population factor) to arrive at about 150gpm for peak flow period. Is this an acceptable method?
RE: peak flow calc in mobile home park
However, it probably does not matter as you would probably be using a 3-Inch water pipe in any case. The cost diffence is insignificant between 2 & 3-Inch.
http://www.wbdg.org/ccb/browse_cat.php?c=4
Also pay particular attention to the references. If you can't find adequate answers in the main PDFs the references will have some information.
These documents are widely used reference materials that you can refer to in a report if you have no particular design criteria.
