Creating a Buckyball In Abaqus
Hi Guys,
For my fourth year project I am trying to create a Buckyball, otherwise known as a C60 element in Abaqus. I have modelled the structure in Solidworks but unfortunately do not have the licence available to create enough nodes to analyse this in Abaqus. I am fairly new to the software but am attempting to model it as 60 nodes connected by beam elements.
From my research on spaceframe modelling it always seems datum planes have to be created to allow you to sketch the shape but I seem to have managed to create the geometry by simply creating the 60 nodes as datum points using their given coordinates, joining them with wires and then giving the wires a profile and section. Is this approach not feasible in the long run? Is there a different way to go about creating the geometry. Im not interesting in molecular forces, it is solely a structural problem.
Any help or advice would be much appreciated.
RE: Creating a Buckyball In Abaqus
Thanks again for the help
I made this using pyFormex in about 5 minutes.
The basic pyformex script is attached. If you have Linux, I suggest you install it and check it out.
To make the model I c/p the coordinates from a website, and connected the nearest points.
