Amada Lasmac LC1212a2....
How do you change the the standard focal position? When M100 (laser mode on) comes up in the program, the focal point goes to .15 all the time, when most of my cutting i do is around .4-.6. Its very annoying and time consuming and in the operator manual, it says it can be adjusted in the parameter screen but does not list a number to adjust, does anyone know how this can be changed and how to do so, thank you!!
RE: Amada Lasmac LC1212a2....
N100 G90 G92 X50. Y50.
N105 M102 (C-SS0.105)
N110 E3
N120 M100
http://www.amada.com/site/default.asp?format=html&...
I hope this helps.
Two places to adjust focus on this machine. "base focus position" is set by pressing the left most key on the cutting conditions page "custom" then press the param. Its almost to the bottom.
Other place is on the custom page it self. Only the top line, E1, has any effect on the focus position. You can change the others if you want but they don't do anything.
