Electropolishing is warping my thin stainless parts
I have some stainless parts that I am electropolishing, the parts are discs that are 0.2mm thick and 15mm in diameter. What I'm finding is that they are warping and I can't figure out what will stop them warping. I can't change the thickness which is very thin and I've reduced the current so much that they seem to take forever to finish - 4 hours! I'm removing about 0.05mm thickness all in and losing maybe the same in diamter, that is ok and what I want, it is just that I want them to stay flat. What is happening do you think? Any pointers?
RE: Electropolishing is warping my thin stainless parts
I'm using very hard 17-7Ph that came in condiditon C and has been preciptation hardened.
Thanks, Ant.
If so, can you terminate the periphery of the disc and electropolish both faces at once?
Separately from that:
The increased warping with higher current density suggests localized heating, possibly from random concentration gradients in the electrolyte.
Are you agitating or circulating the electrolyte?
Can you/ do you use a shaped cathode? E.g., a faced rod of the same diameter as the disc, located in close proximity to the disc?
Mike Halloran
Pembroke Pines, FL, USA
This will at least give you some natural convection.
A simple agitator would help, Just something to gently stir the solution.
Make sure that your connection to the part covers a large area, preferably all of the back.
Your cathode should match your part shape.
Uniformity is your friend.
I presume that this material is in the CH900 condition.
How much machining was done after aging?
It might be worth re-aging (at 885) part way through machining.
You may have way too much internal stress.
Plymouth Tube
I will use a disc instead of a rectangular sheet and ensure that the connection is much bigger, I think just the wire in one spot will be causing a problem.
The bath/tank i'm using is shaped to prevent bubbles sticking under the part and that does seem to work.
Ant.
As long as you don't exceed the original temp you shouldn't change the strength, but staying just below it is a good precaution.
Plymouth Tube
