SACS-weights option
SACS-weights option
Can anyone explain how to use the weights corretly in SACS.
I defined various types of weights on the structure & created load conditions by including weight groups. But when I run the analysis I couldnt see any reations due to these weights.
Is weight groups need to be used only with accelaration? Cant we use weights instead of load to analyze the structure.
Please help!!
Please help!!
RE: SACS-weights option
Kennedy
Do I need to use accelaration in Z as 1 alwys in combination to Z in along other axis..
If u want to use weight to generate load in sacs, there are 2 following steps
1. Define weight in weight menu
2. Generate load using environment/loading menu (i. define center of roll, ii. define acceleration (z dir), iii. includ wt group u want to apply as load
rgds
But if I dont have any acclarations & centre of roll. I want to check if we can analyze the model using weights instead loads
u can define trans acceleration z = 1g and center of roll default 0,0,0
rgds
