NX7.5 - Pipe management
Hi!
Please, open the attached file.
I need to modify the end of the small pipe's path in such way that the gray end of it would enter perpendicular inside the yellow pipe and concentrically on the Hole (1).
All arcs radius should be 20mm.
The brown segments of the small pipe should not be modified. The grey ones can be adjusted(the little the impact, the better)
I'd like to keep the location of the pipe as close as possible with the current one.
I have created the Trim Body (3) in order to give you a better view.
Since I’ve run out of personal option in this matter, I am asking your opinion.
MZ7DYJ
RE: NX7.5 - Pipe management
John,
You posted a a part that does have nothing to do with my request........
It is something related to Sheet Metal......!
MZ7DYJ
I'll withdraw the star I gave you!....(LOL)!
MZ7DYJ
Thanks a lot!
MZ7DYJ
