Tabular Notes in NX 7.5
I am using Tabular Notes in Drafting, but my problem is that I cannot insert more than 35 lines without the tabular note separating into two tables, when I actually need them as one.
I have looked everywhere for an edit option to increase the amount, but I cannot find it.
Any suggestions?
RE: Tabular Notes in NX 7.5
Change the note's style to increase the maximum height (style -> sections -> maximum height).
www.nxjournaling.com
Touch the upper left corner of the table (so the entire table highlights) and go Style
You will see a Maximum Height setting. Change that to a higher number.
Awesome!!!
Thanks...
