Part copy visibility in drafts
Hi All,
I couldn't find a forum post for the following:
When I download and import Step files from various companies, the imported parts are often composed of a *set* of Part Copies. Apparently I can only make one of these a Base Feature. Importing as Part or Assembly doesn't seem to offer a solution.
The problem comes in the Draft: there only the Base Feature is visible. I couldn't find any view property options to fix this.
Is it possible to make Part Copies visible in the Draft (or is there a fundamental problem, e.g. that they are not true solid bodies)?
Is the Feature Recognizer during import the only possible solution?
(although I try to avoid this, as the import procedure seems sometimes to get a bit out of hand)
Regards, MT
Regards, MT
RE: Part copy visibility in drafts
Tony
To get them to display -
In draft, right click the view then Properties.
On the Display tab right click the part and select List Constructions
Select all the surfaces and then check the Show box.
Click OK then update the view.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
Many thanks, that did the trick.
Regards, MT
Ken G.
http://grundey.blogspot.com
