Closed ended cylinder radial expansion
Good morning guys/girls, hope all of you are well. I have a question - I want to find out the formula to use when calculating the radial expansion of a close ended cylinder under pressure. i have looked around but can only find formulas regarding open ended cylinders.
Your help would be appreciated...
RE: Closed ended cylinder radial expansion
You are in the wrong place.
Please consider Mechanical Engineering/Machine Design forums
