Electromagnetic Latch
Hi, I am trying to find information on creating an electromagnetic latch. Allow me to explain using object A and object B. I would like object A to have a permanent magnet that attracted an iron bar on object B. The iron bar would be the core of an electromagnet. When power is applied, I am hoping there is enough of a disruption in the attractive force to separate object A from object B. Does this sound feasible? In searching the internet, I am coming across a lot of questions asking about levitation. This is not what I'm interested in, I simply want to disrupt the attraction long enough for object B to fall away with gravity. Any thoughts?
RE: Electromagnetic Latch
Folger Adam
HES
Securitron
Adams Rite
Bosch
Von Duprin
You'll find a number of others if you google "electric strike" or go thru the ADI online access control catalog. A spring is a lot more common than a permanent magnet to retain the latch in the normally-closed or normally-open position.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
