The top setting on my Assembly Load
The top setting on my Assembly Load Options is set to As Saved
I opened up the assembly and the parts are not located where they were saved, so they were not loaded.
Is there a way to find the "saved" location of the file in an assembly that was not loaded ?
I am on NX7.5
I am on NX7.5
RE: The top setting on my Assembly Load
Information - Assemblies - List Components, it will list the original path where your file saved.
Raj
NX 7.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Actually it will show the unloaded component part saved path also, I tried by deleting some of the components from the existing assembly.
Raj
NX 7.5
If you are looking for the current location of the parts, I'd suggest using a desktop search tool.
A few years ago, I wrote a script that used ugpc to list the as saved assembly location. If the file did not exist there it would search through some user defined directories; if/when the part was found it used ug_edit_part_names to update the assembly to point to the correct component part file location. Perhaps I should put this in my queue of "projects to develop further".
www.nxjournaling.com
We recently switched to WINDOWS7 and the search tool is terrible on there.
Initially, I hated it; still don't like it, but it is growing on me bit by bit. At least they provide a link to start the "search companion" which will open an XP style search window.
John Lackowski
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
http://www.voidtools.com/
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I just opened an assembly with the "structure only" option and tried out vrishraj's suggestion. If I scroll all the way to the right in the resulting information window, there is a "directory" column that lists the component's directory. I have a few in my list that are empty and when I try to load the component, it cannot be found with my current load options.
Information -> Assemblies -> List Components
...this is what I get as a result:
Note that this was done using NX 7.5, but I've also checked NX 8.5 and nothing has changed.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
