LVL support between 2 masonry walls
Existing building, with a room 20' wide and a 3-ply 18" deep LVL required (spanning from 8" hollow block wall to wall), for purposes of getting a 19'-10" long beam into the room, any ideas how to support the beam at the face of the block walls with minimizing eccentricity on the connection? The 19'-10" length helps get the beam into place.
Thank you
Thank you
RE: LVL support between 2 masonry walls
http://www.strongtie.com/products/categories/mason...
You may want to consider this type if eccentricity is an issue.
http://www.strongtie.com/products/connectors/MBHA_...
