new steel beam to existing circular conrete colum
I need a 4ft Steel I beam cantilever to connect to an existing 20" dia circular concrete column. This seems simple by just drilling holes then adding threaded rod and end plate.
i'm concerned about hitting column rebar though and the end plate will be semi circular.
any suggestion?
any suggestion?
RE: new steel beam to existing circular conrete colum
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
what is the best way to connect to existing given the situation?
http://www.proceq.com/en/products/concrete-testing...
