Flushing an I beam
Flushing an I beam
I am in need of some advice.
I had a company move an existing steel beam flush with the joists to add head room in a basement. They "packed" the web of the beam with 2X material and hung the joists from that with joist hangers. They used powder actuated nails and glue to attach the 2X material to the web of the beam, is this acceptable or should they have bolted the wood to the beam? also they did not use top mount hangers they are regular hangers attached only to the packing in the beam
Thanks in advance
Thanks in advance
RE: Flushing an I beam
The detail you mentioned is not that uncommon. If you are concerned, please have an engineer look into it. He may be able to tell whether the contract has used the right type and number of powder actuated fasteners. Any detail is acceptable as long as a rational approach has been followed to arrive at it (obviously by and engineer).
As Ron Mentioned, special thicker and weldable top hung hangers are available from Simpson.
Watch out though. Not all of the hangers can be welded - some are too thin or not rated for that type of attachment.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
don't see a reason for thru bolted fasteners here, when even paf's have comparable pullout resistance when driven into steel.
