Br and Hc from 1 T or from Bs
there is a specific reason why for relay application of both ferritic SS or Si-Fe alloys, Br and Hc values are generally required misuring at the maximum flux density of 1 Tesla ( 10kG) instead of saturation flux density Bs ?
RE: Br and Hc from 1 T or from Bs
No.2, the applications are not intereted in the higher fields.
note that people normally use 200Oe as the test point to get Hc for FeCo, use 5000Gs test point to get Hc for Fe-80Ni permally (ASTM A753 alloy type 3,4.
