"Killed" Error
"Killed" Error
"Killed" Error
I'm running an ANSYS analysis on a UNIX machine and I'm getting a "Killed" in the output and then continues to run but at some point it stops. What does "Killed" means? What is happening?
Thanks.
RE: "Killed" Error
Kill is a Unix term meaning to abort a process.
So for some reason your analysis is aborting.  You'll have to post the entire error msg, as well as the version of ansys you are running and your operation system & specs if you want any help.
