Hi everybody, I have a question
Hi everybody,
I have a question I've been working on these days, and honestly, as I am a newbie in CATIA I cannot solve it. Here's the deal. I have a bunch of surfaces which define a closed volume, although actually no volume is defined in CATIA. What I want is to create a copy of these surfaces, resulting a new scaled (1.1, so bigger than former) volume, something from a normal-direction-scale. This is pretty easy, but what I want is that this new 'volume' is bounding the first one with the same distance all along it. I mean, I want like a bark or crust envolving the first one, but I am only interested on the external surface. When I tried by copying and scaling all the surfaces, the problem is that this distance is not the same everywhere as there are some surfaces I want only them to 'grow' in the normal direction.
I know there is a extra tool, Affinity, which allow you to fix how much each dimension varies by defining a new axis system. The problem is that as each surface has a different normal direction I don't know how to do it.
Any idea about how to deal with it? Maybe the solution is creating the volume and making an offset of it?
Thanks in advance,
/L3munoz
Thanks in advance,
/L3munoz
RE: Hi everybody, I have a question
