Pressure drop inside pumps seal
Hi!
Could you help me, please?
I'm reading a manual about pressure drops along a pump seal. I understand that the mechanical seals have two parts: stationary seal and rotationary seal. Between them there is a gap, and the gap is filled with the pumped fluid. But I don't understand very well why the pressure drops linearly when the rotational seal starts to rotate and why it becomes some kind of "cuadratic" distribuition when the seal is rotating. I understand that the gap is just a few microns wide, so perhaps the fluid mechanics has a special formulas for these situation. I'm taking these information from page 15 of the Grundfos Pumps Manual. Please your kind help.
Link
Thanks!
Az
RE: Pressure drop inside pumps seal
It becomes noticably quadradic when frictional pressure due to the velocity squared term becomes more prominent.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
