Lightning strikes
Lightning strikes
Can the neutral line of a 13.8 kV withstand a lightning strike?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Lightning strikes
What do you mean withstand? Will it burn down? Flash over?
Lightning is a highly variable parameter with a wide range of current and a wide range of waveshapes. Also, you can get multiple strikes.
So, if you frame your question in terms of some specific limits, you might get an answer.
Also, what size neutral are you considering? Is this related to your other post?
Bill
"Why not the best?"
Jimmy Carter
