heat treat thickness vs as-forged thickness
AMS 4141 para 3.3.1.1.2 speaks for an as-forged thickness and a heat treat thickness. What is the difference? Why wouldn't they both be the thinnest direction in the forging?
RE: heat treat thickness vs as-forged thickness
I don't have a copy of AMS 4141, but with your 7075-T73 material there can be reduced mechanical properties through thicker sections. In order to achieve optimum properties after heat treat, it is common to rough machine all surfaces to within a couple mm of the final shape (even die forgings) and then put the part through heat treatment just before final machining. This approach would present the minimum section thicknesses during heat treatment and yield slightly better mechanical properties in the finished part.
I've attached the relevant table from MIL-HDBK-5 showing the reduction in min. mechanical properties for 7075-T73 die forgings versus section thickness.
Hope that helps.
Terry
It looks like TVP provided an answer to your question on the other thread, and I would agree with it. The T7352 spec includes a post-heat treat mechanical stress relief, while the T73 spec does not. The less residual stress there is in the part before you begin final machining the less it will move around during/after final machining.
Terry
