Toshiba BACnet Server - BMS-STBN08E
Hi!
Anybody got experience with this? Tried connecting this to our BMS but not able to read the objects such as BO,AI, AO. Able to read the gateway device properties only (such as object name, firmware revision).
Not too sure if I am reading the manual (as attached) correctly such as:
On/Off status for 1st AC as BO-0182
On/Off status for 2nd AC as BO-0282
Error status for 1st AC as BI-0140
Error status for 2nd AC as BI-0240
Any help would be appreciated.
RE: Toshiba BACnet Server - BMS-STBN08E
I may be able to help..
Download our BACnet Test Client at www.bac-test.com/download.php and run the diagnostics. There is a button in the middle of the screen that will take you to the logfiles. Attach these logfiles to a new support ticket that can be created by clicking on the link on the main form (https://bacnet.zendesk.com) and I will do my best to respond.
Ed
thank bacneted ....will post once i go to site again soon.
