Output data from Path -> Point list
Hi Everyone,
I've been looking everywhere and can't seem to find a solution to my problem. I have run a simulation and I would like to extract some data from a Point List that I have created.
The way I have set up my simulation is to create a single step with a fixed number of increments (200) with an increment size of 0.005. I have applied a maximum load and then run the simulation so effectively, each increment is equal to a certain load (e.g. if my final load is 200 kN, each increment would be equal to an extra 1kN). I know how to extract displacement data for each increment one at a time, but I would like to extract displacement data for all the increments in one go. I know I can do this using an ODB Field Output but then I can't select a specific point and have to interpolate between different nodes/elements. Does anyone know a way I can extract the data for all the increments in one go for a given output like displacement or strain?
Thanks in advance
Thanks in advance
RE: Output data from Path -> Point list
2) If you are familiar with Python, scripting is a very convenient way of achieving this.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
