Working with inches and pounds in Abaqus
Hi all,
I'm doing the FEA of a concrete canoe model in Abaqus and I can't figure out what's wrong with my units. I am using inches as my distance unit and pounds as my units of mass. In my FEA model I'm tring to simulate the canoe sitting on two stands. The only load acting on the canoe is its self-weight, which I have applied as a gravity load. The model runs alright but the values for the max/min stresses seem quite absurd. I was wondering if anyone would know of the correct units to use when one is working with inches and pounds. I've been told to use slinches as the unit of mass but I'm also not sure if that's the right way to do this. I have listed the parameters I used in the model with the units I assumed Abaqus would be using in the computation. Let me know if more information is required for you to understand this.
Parameters used for the model:
- Unit weight of concrete: 0.0348 pci (60.1 pcf)
- Young's modulus: 571,000 psi (571ksi)
- Poisson's ratio: 0.17
- Thickness: 0.75 in
- Gravity: 386.4in/s^2 (=32.2ft/s^2)
For comparison:
Compressive strenght of concrete cylinders: 2078psi
From the model:
- Max compressive stress: 11460psi (=165.03 x 10^4psf)
- Min tensile stress: 1.062 x 10^-27psi (152.93 x 10^-27psf)
Thank you for your time
For comparison:
From the model:
RE: Working with inches and pounds in Abaqus
Do you have contact conditions present? If so, are the extremes at the edges of the contact areas?
Han primo incensus
Han primo incensus
Han primo incensus
