NX7.5 Finish Symbol
NX7.5 Finish Symbol
NX7.5 Finish Symbol
I placed a finish symbol on a drawing using the flag leader.
I have tried everything but I cannot get the symbol flipped to the other side that it was placed down as, changing that angle does nothing.
Is there a way to flip the finish symbol to the other side of the extention line ?
Also,
Is there a good way to place the finish symbol on the shaft end using the flag leader ?
The end of the shaft appears as a staight line in the view, but it actually is an arc.
RE: NX7.5 Finish Symbol
Jerry
Mine is based on cursor position, whilst the symbol is live, depending on which side of the extension line I move the cursor the symbols moves to the same side???? If I then click and hold once it is placed and drag it will also change sides.
Best regards
Simon NX7.5.4.4 MP8 - TC 8 www.jcb.com
NX7.5
I think my problem is that I need to place a finish symbol of the end of the shaft, so what I needed to do was place a 2d centerline across two points on the end of the shaft and place the flag leader on that, so that I have something to attach the leader to.
I got a new computer a few weeks ago, and when it was loaded they installed NX7.5.0
Today I noticed the problem, so it was updated to NX7.5.3.3, and the problem with the finsh symbols not flipping went away.
So I guess the moral of the story is to make sure you are running the best update of the version that you are running.
