Finding Fridays
Finding Fridays
I'm looking for some VB code that will find the following Fridays from a given date in a cell.
> The first Friday following the given date
> The first Friday in the month of the given date
> The last Friday in the month of the given date
I have a fairly crude way to get the first but am having trouble with coding the others. Any suggestions will be gratefully considered.
Dennis Kirk Engineering
www.ozemail.com.au/~denniskb
RE: Finding Fridays
A1 is the current date.
A12 is the first Friday after the current date:
=A1+6-WEEKDAY(A1,1)
A16 is the first day of the current month:
=EOMONTH(A1,-1)+1
D16 is the first Friday of the current month:
=A16+6-WEEKDAY(A16)
A20 is the last day of the current month:
=EOMONTH(A1,0)
D20 is the last Friday of the current month:
=IF(MONTH(A20-1-WEEKDAY(A20))=MONTH(A20+6-WEEKDAY(A20)),A20+6-WEEKDAY(A20),A20-1-WEEKDAY(A20))
RE: Finding Fridays
http://www.geocities.com/flareman_xs/datePage.html
I have put up an Excel sheet which does this.
RE: Finding Fridays
RE: Finding Fridays
You could mod your current date. Then have a cell that subtracts that value from 5. Add this number back to your mod'd date, and you have the next Friday's date.
GB
RE: Finding Fridays
RE: Finding Fridays
Enter a date in cell A1
Next Friday
=IF(WEEKDAY(A1,2)<5,A1+(5-WEEKDAY(A1,2)),A1+(12-WEEKDAY(A1,2)))
Last Friday of month
=IF(WEEKDAY(EOMONTH(A1,0),2)=5,EOMONTH(A1,0),IF(WEEKDAY(EOMONTH(A1,0),2)<5,EOMONTH(A1,0)-(WEEKDAY(EOMONTH(A1,0),2)+2),IF(WEEKDAY(EOMONTH(A1,0),2)>5,EOMONTH(A1,0)-(WEEKDAY(EOMONTH(A1,0),2)-5))))
First Friday of month
=IF(WEEKDAY(EOMONTH(A1,-1),2)=5,EOMONTH(A1,-1)+7,IF(WEEKDAY(EOMONTH(A1,-1),2)<5,EOMONTH(A1,-1)+5-(WEEKDAY(EOMONTH(A1,-1),2)),IF(WEEKDAY(EOMONTH(A1,-1),2)>5,EOMONTH(A1,-1)+(12-WEEKDAY(EOMONTH(A1,-1),2)))))
RE: Finding Fridays
With the various tips provided I have managed to solve this one now, but in the worksheet, not in VBA.
If anyone wants it I will be happy to forward the spreadsheet. Contact me at denniskb@ozemail.com.au
RE: Finding Fridays
If you or anyone else is interested, here are some VBA functions that do what you required. These can be used as worksheet functions in addition to being called from within a VBA procedure. Supply a valid date as the argument (or cell reference containing a date). These will convert a Date+Time input and return a Date only value. There are a couple of additional functions here that the others require but could also be used directly. The Demo_DateFunctions procedure just demonstrates usage of these functions.
Sub Demo_DateFunctions()
MsgBox "First Friday after date: " & FirstFridayAfterDate(ActiveSheet.Range("A1"))
MsgBox "First Friday of Month: " & FirstFridayOfMonth(ActiveSheet.Range("A1"))
MsgBox "Last Friday of Month: " & LastFridayOfMonth(ActiveSheet.Range("A1"))
End Sub
Function FirstFridayAfterDate(ByVal DateVal As Date) As Date
Dim WkDay As Integer
DateVal = Int(DateVal)
WkDay = Weekday(DateVal)
If WkDay = 6 Then
FirstFridayAfterDate = DateVal + 7
ElseIf WkDay = 7 Then
FirstFridayAfterDate = DateVal + 6
Else
FirstFridayAfterDate = DateVal + 6 - WkDay
End If
End Function
Function FirstFridayBeforeDate(ByVal DateVal As Date) As Date
If WkDay = 7 Then
FirstFridayBeforeDate = DateVal - 1
Else
FirstFridayBeforeDate = DateVal - (WkDay + 1)
End If
End Function
Function FirstFridayOfMonth(ByVal DateVal As Date) As Date
Dim Mnth As Integer
Dim Yr As Integer
Dim DateTmp As Date
Mnth = DatePart("m", DateVal)
Yr = DatePart("yyyy", DateVal)
DateTmp = DateSerial(Yr, Mnth, 1)
If Weekday(DateTmp) = 6 Then
FirstFridayOfMonth = DateTmp
Else
FirstFridayOfMonth = FirstFridayAfterDate(DateTmp)
End If
End Function
Function LastFridayOfMonth(ByVal DateVal As Date) As Date
Dim Mnth As Integer
Dim Yr As Integer
Dim DateTmp As Date
DateTmp = DateSerial(Yr, Mnth, DaysInMonth(Mnth, Yr))
LastFridayOfMonth = DateTmp
Else
LastFridayOfMonth = FirstFridayBeforeDate(DateTmp)
End If
End Function
Function DaysInMonth(ByVal Month As Integer, ByVal Year As Integer) As Integer
Select Case Month
Case 2
If IsLeapYear(Year) Then
DaysInMonth = 29
Else
DaysInMonth = 28
End If
Case 4, 6, 9, 11
DaysInMonth = 30
Case Else
DaysInMonth = 31
End Select
End Function
Function IsLeapYear(Year As Integer) As Boolean
IsLeapYear = (Month(DateSerial(Year, 2, 29)) = 2)
End Function
Mike
