NX Advanced Simulation
Hye All,
I would like to ask a question on NX Advanced Simulation settings. I am working on a hinge separation test analysis.
From the actual test, they run the test by pulling the hinge in both linear opposite direction at 5mm/min until failure.
The problem is I do not know how to apply the 5mm/min setting in this NX Nastran structural analysis. Anybody have the ideas?
RE: NX Advanced Simulation
forum561: Siemens: UG/NX may provide you with better feedback. Good luck!
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Thank you for the suggestion. :)
