Family of parts, and variables
Fairly new to SolidEdge, so I'm hoping I'm just overlooking something obvious. Anyway.
I created a family of parts. The 'parent' has a variable for the length of the part, and the numerous 'children' are all just variations of this variable.
When I insert the part into an assembly, it works fine, but if I try to put it into a schedule, there is no length variable that I can expose.
If I go into the individual family of parts .par files, I can add a dimension, and then create a length variable, but it seems like I should be able to pull that out w/o having to go into each and every member of this family of parts.
Any suggestions, tips, tricks, would be appreciated.
RE: Family of parts, and variables
As you have found, Solid Edge creates seperate part files for each family member, therefore any variables that you need to extract into a parts list (through an assembly) will have to be in each part file.
Drawing is a different matter - you can use the family part master file and then tabulate dimensions for all members.
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
I'm seeing that. Just would be nice, during the creation of the family of parts, if you could elect to have exposed variables in the parent part 'tag-along' automatically when you populated the family.
