Rougness symbol
Rougness symbol
Hi Guys,
Does anybady know how to create a roughness symbol in a drawing?
Thanks!
Ruiguo
Thanks!
Ruiguo
RE: Rougness symbol
RE: Rougness symbol
Up to r18 I couldn't find a way to create this symbol by macro, I don't know for upper versions....
You can draw it by macro (two lines with V shape) but I don't think you want this....
Fernando
https://picasaweb.google.com/102257836106335725208
RE: Rougness symbol
1. can I fix those lines?
2. Can I setup line spacing for the text?
Br,
Ruiguo
RE: Rougness symbol
1) Why do you want to try to fix them, is it ant reason to do that? Usually designers are not working in background view so often so the risk to "touch" those lines is small...
2) Line spacing...I would try to write text line after line and setup a distance between them thru the anchor point coordinates of text
Fernando
