How can I add the file path as a note on Drafting?
I'm not sure if this can be done, but I was wondering if one could add the full path of the file (as it appears on the Part Property dialog box) as a note on Drafting module.
Thanks in advanced,
Alex H.
Thanks in advanced,
Alex H.
RE: How can I add the file path as a note on Drafting?
Ben Loosli
thread561-242216: Extracting full file path into drawing
www.nxjournaling.com
http://www.eng-tips.com/viewthread.cfm?qid=336503
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John.
I have another question. I have almost zero experience with programing, so I'm not sure if it would be possible to change the file that recommended on the posts, because I would like to add the date the Draft was created as well. I want to create a template, so instead of writing out the date, I´d just run the GRIP files, and all the info will be filled out.
What software can I use to change the code?
Alex H.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If it is possible I would like the date to be dd/mm/yyyy.
How does one modify this file?
Alex H.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for all your help.
Alex H.
I don't NX running here, but here is a modifed source code to add what you want.
Date is formatted as you wanted with 0 filled for less than 10.
Ben Loosli
Note that I've fully annotated the source code so that if anyone wants to use it for themselves it'll help them to better understand what the program does and how it goes about doing it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Any chance on getting a modifed grip program based on the US standard of MM/DD/YYYY?
That woould help us immensely if we could have that.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks a million!
Ryan
P.S. Thanks again for flying out to Cincinnati last month as well for the NX RUG.
Ryan Gudorf
CAD/CAM Supervisor
305 Leo St.
Tel: 937.224.0868
Fax: 937.224.1356
