Raising air pressure in a single bedroom by 1.5psi or 2.5 InHg approx?
Hi, I live at 7000ft and spend a lot of time at 10000 ft altitude. However, I have a horrible time sleeping at the 10000 ft elevation. (horrible == hardly at all and poses a medical risk unfortunately).
Talking with a sleep specialist, it is obviously pressure related (along with O2 concentration).
I am wondering if it is possible to raise the ambient pressure in a bedroom by 1.5psi or 2.5 In. Hg. Abs easily? Or, is this just a dream?
What if cost is [mostly] not an issue? Can someone point me in the right direction on more research or who I should talk with?
Thanks!
Thanks!
RE: Raising air pressure in a single bedroom by 1.5psi or 2.5 InHg approx?
Door: 30" x 84" x 1.5 PSI = 3780 lbf. If the door opens into the bedroom, I don't think I could get out. I'm betting the windows wouldn't appreciate that level of pressure either.
That's a tough problem. Can you do an oxygen tent?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
To limit the pressure on doors and glass (and walls), the highest you want to be is about 0.25" H20 pressure difference. That's about 0.009 PSI or 25 lbf on a door. You might be able to mitigate that with an airlock entry (refer to 2001 - A Space Odyssey for an example. The room would have to be sealed really, really well. Think submarine.
Best to you,
Goober Dave
TTFN
Most likely your problem is oxygen concentration, not pressure. So try a mask or cannula.
If you really want to sleep in a higher pressure environment, consider a pre-made hyperbaric chamber rather than making an attempt at a DIY version.
TTFN
Only half kidding here, dbreese: You could make a sleeping chamber, I suppose. Small space that looks like a bank safe, maybe even a large diameter pipe with an airlock door on one end? I envisioned an iron lung that encloses the head as well as the body.
Be safe, though. If the space is tight enough to pressurize, it's tight enough to suffocate you. I would alarm the tar out of it and have a super-reliable backup ventilation system.
Good luck with it, that sounds like a tough time you're having.
Best to you,
Goober Dave
TTFN
does it mean that everyone living in your area has the same or similar problem or only you?
I think you need a medical help not engineering help.
Thanks again for input from everyone. Sounds like I'm back to the drawing board!
