Material Selection for Submersible Centrifugal Seawater Pump
Hello :)
I've been assigned to recommend materials to be used for different parts of a submersible centrifugal seawater pump. I need to select commercially available materials for construction of the following parts of the pump:
1.) Pump Casing
2.) Impeller
3.) Shaft
The seawater pump will be used in the environment with the following conditions:
Total Dissolved Solids: 25,000 ppm
Operating Pressure: 10 bar gauge coastal seawater
Operating Temperature: 30 degrees Celsius
Location of Pump: 10 meters from coastline into the sea
Any reference to a website or pdf file will also be useful.
1.) Pump Casing
2.) Impeller
3.) Shaft
RE: Material Selection for Submersible Centrifugal Seawater Pump
How many will you make?
Will they be permanently installed or regularly transported and handle roughly maybe?
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
http://in.grundfos.com/content/dam/Global%20Site/I...
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
http://www.copperinfo.co.uk/marine/
http://www.nickelinstitute.org/KnowledgeBase/Techn...
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
How deep? what will the oxygen content be?
If no O2 then Ni-Resist will work, if there is any O2 then you need high alloy SS.
Duplex would be your best bet.
Plymouth Tube
Pat
for site rules
I know salt water won't be an issue.
Abrasion resistance might be.
Tooling costs may very well be an issue hence my original question.
Pat
for site rules
A number of thermosets have been used, Ryton is one that comes to mind.
Depends on the pump size. For large pumps metals work better.
Plymouth Tube
It is used extensively in pumps for fire fighting and for underground mining. Sure, they are relatively small but the OP makes no mention of size along with a lot of other data required to make a valid recomendation.
Polyester holds shape and clearances a bit better but is not normally tough enough for rough handling.
Ryton is PPS (polyphenylene sulphide) and is a thermoplastic, not a thermoset. It is hard and strong but quite expensive. It's main reason for selection is for its high temperature resistance which does not apply here.
Pat
for site rules
In response to the questions, I will try to answer the questions posted below:
Q: "Will they be permanently installed or regularly transported and handle roughly maybe?"
A: The pump will be permanently installed on-site. My question is that will the recommended material change if the pump is to be regularly transported?
Q: "How deep? what will the oxygen content be?"
A: The pump will be installed 100 meters below sea level. I haven't found out the oxygen content but I guess there will be small amounts of oxygen dissolved in seawater. I will let you know once i find out the oxygen content.
Q: "will the pump be operating intermittently or continuously and if there is scheduled downtime, how long will it be?"
A: The pump will be operating continuously although I don't know how long the down time will be. May I ask how does the downtime affect the material that will be used for the pump? i.e. will a pump with a longer downtime require a different material?
I would like to thank everyone for their responses.
The more variable the operating conditions (stand by, high flow/low flow, change in temp or oxygen) then the more corrosion resistant the materials must be.
I don't know how you will install a pump this deep when you are right at the coastline.
For deep set, fixed location seawater pumps there are a few choices.
Traditionally the stages (impellers and bowls) would be cast Nickle Aluminum Bronze, with shafts and bolting all Monel.
It is hard to beat this combination in seawater service.
Another traditional option would be to use cast Ni-Resist pump stages. These are used commonly in high salinity applications.
If you move to SS construction you need to asses some risks. You should be able to use alloys that would not be suitable for surface use since you will be colder and lower oxygen.
Plymouth Tube
For shaft and impeller, we were thinking of using some stainless steel of higher quality as the impeller and shaft will experience a higher water velocity (pump operating at 10barg). We are thinking of using super duplex stainless steel, AL-6XN, since the PREN is 45.4.
My team and i did consider Ni-Cu for pump casing but we were thinking it might not be very suitable as it will cause galvanic corrosion if we use NiCu for pump casing and AL-6XN for impeller and duplex.
So, do you think the materials selected will work out?
The key question is what alloy combination does the pump manufacturer offer?
Don't ask for the impossible.
Plymouth Tube
As to materials, my experience starts with CuNi and bronze as a low end option, moves up to monels, then C22, then inconel/titanium. It all depends on what you want afor service life and maintenance requirements.
I have seen NAB pumps run in seawater for decades.
In general teh Cu alloys will not suffer crevice corrosion and will have less bio-fouling. This is a combination that can be very tough on even high alloy SS units.
Plymouth Tube
