FEA models in Algor or Inventor
I occasionally need to perform FEA for pressure vessel design and have access to Algor MES 2011 and Inventor Routed Systems 2011. I want to know if it would be easier, that is less time to learn and use, Algor to create the models and then run the FEA or create the models in Inventor and then import them into Algor.
RE: FEA models in Algor or Inventor
