ATP/EMTP TACS
ATP/EMTP TACS
Dear Friends;
I am facing some problems in simulating speed control of Drives, since I do not have access to motor speed parameter; I need to get it with TACS in ATP-EMTP. In ATP, the "coupling to circuit" TACS element used for exporting a parameters, which node do I connect this element. And what is name that ATP saved?
RE: ATP/EMTP TACS
The TACS coupling is connected to the node where the variables are available.
Name of the file? When you save the file, you select the name. If you are working with ATPDraw, the extension is *.acp, for example mycircuit.acp. The atp file is automaticially saved with the same name, with extension *.atp, as mycircuit.atp
RE: ATP/EMTP TACS
but for exporting machine speed, which node of UM3?
And what is name that TACS saved for machine speed variable?
RE: ATP/EMTP TACS
Name? Sorry, don't understand the question. If you connect a simple multiplier (left click, TACS | Fortran statements | math | x*K. In addition, do not forget the TACS-probe at that node!) then the output of this multiplier = the name of the output node = speed multiplied by K. The input node must then be the name of the speed, I guess.
